[Qgis-user] Re: Mac OS X, Sextante and other plugins or the forgotten users..
Julian Bogdani jbogdani at gmail.com
Sun Apr 1 04:01:20 PDT 2012
http://plugins.qgis.org/plugins/plugins.xml
Julian Bogdani
http://bradypus.net
On 1 Apr 2012, at 12:57 , Noli Sicad wrote:
> I did what you outlined, SEXTANTE is not showing.
> Could you just tell me what is the URL of the QGIS Official Repository 2?
> Just click Edit and you will see the URL, the second line.
> Thanks.
> Noli
> On 4/1/12, Julian Bogdani <jbogdani at gmail.com> wrote:
>> In QGIS:
>> Plugins > Fetch Python Plugins
>> Repositories: "Add third party repositories"
>> Options: select "Show all, even those marked as experimental"
>> Plugins: filter type sextante
>> You'll see it in the list (under repository you'll find QGIS Official
>> Repository 2), go ahead and install.
>> Julian Bogdani
>> http://bradypus.net
>> On 1 Apr 2012, at 12:34 , Noli Sicad wrote:
>>> What is the QGIS Official Repository 2, could give details on this.
>>> It seems that I am not getting SEXTANTE as well in my Mac OS X QGiS.
>>> Thanks.
>>> Noli
>>>> Hello,
>>>> I'm running QGIS on MacOS also, and having problems with SEXTANTE. I was
>>>> able to successfully install it from the QGIS Official Repository 2, but
>>>> SAGA does not work.
>>>> Here is the log for a simple points to lines analysis:
>>>> ALGORITHM|Sun Apr 01 2012
>>>> 12:16:46|Sextante.runalg("saga:convertpointstoline(s)","/Users/jbogdani/qgis/points.shp","cat1","cat2",None)
>>>> INFO|Sun Apr 01 2012 12:16:46|SAGA execution commands|libshapes_lines
>>>> "Convert Points to Line(s)" -POINTS /Users/jbogdani/qgis/points.shp
>>>> -ORDER
>>>> "cat1" -SEPARATE "cat2" -LINES
>>>> /Users/jbogdani/sextante/tempdata/1333275406.0329.shp
>>>> INFO|Sun Apr 01 2012 12:16:46|SAGA execution console
>>>> output|/Users/jbogdani/sextante/saga_batch_job.sh: line 1: saga_cmd:
>>>> command
>>>> not found
>>>> Julian Bogdani
>>>> http://bradypus.net
>>>> On 1 Apr 2012, at 12:09 , gene wrote:
>>>>> I installed this plugin (and before the experimental 0.1 from
>>>>> http://code.google.com/p/sextante/source/browse/#svn%2Ftrunk%2Fsoft%2Fbindings%2Fqgis-plugin
>>>>> ) otherwise I could not say that it not works with SAGA or R.
>>>>> View this message in context:
>>>>> http://osgeo-org.1560.n6.nabble.com/Mac-OS-X-Sextante-and-other-plugins-or-the-forgotten-users-tp4676106p4676150.html
>>>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
