[Qgis-user] Re: Mac OS X, Sextante and other plugins or the forgotten users..
Noli Sicad nsicad at gmail.com
Sun Apr 1 04:15:49 PDT 2012
Thank you!
I am not getting that URL.
Now, I am getting SEXANTE using the URL that you supplied.
Thanks.
Noli
On 4/1/12, Julian Bogdani <jbogdani at gmail.com> wrote:
> http://plugins.qgis.org/plugins/plugins.xml
> Julian Bogdani
> http://bradypus.net
> On 1 Apr 2012, at 12:57 , Noli Sicad wrote:
>> I did what you outlined, SEXTANTE is not showing.
>> Could you just tell me what is the URL of the QGIS Official Repository 2?
>> Just click Edit and you will see the URL, the second line.
>> Thanks.
>> Noli
>>> In QGIS:
>>> Plugins > Fetch Python Plugins
>>> Repositories: "Add third party repositories"
>>> Options: select "Show all, even those marked as experimental"
>>> Plugins: filter type sextante
>>> You'll see it in the list (under repository you'll find QGIS Official
>>> Repository 2), go ahead and install.
>>> Julian Bogdani
>>> http://bradypus.net
>>> On 1 Apr 2012, at 12:34 , Noli Sicad wrote:
>>>> What is the QGIS Official Repository 2, could give details on this.
>>>> It seems that I am not getting SEXTANTE as well in my Mac OS X QGiS.
>>>> Thanks.
>>>> Noli
>>>>> Hello,
>>>>> I'm running QGIS on MacOS also, and having problems with SEXTANTE. I
>>>>> was
>>>>> able to successfully install it from the QGIS Official Repository 2,
>>>>> but
>>>>> SAGA does not work.
>>>>> Here is the log for a simple points to lines analysis:
>>>>> ALGORITHM|Sun Apr 01 2012
>>>>> 12:16:46|Sextante.runalg("saga:convertpointstoline(s)","/Users/jbogdani/qgis/points.shp","cat1","cat2",None)
>>>>> INFO|Sun Apr 01 2012 12:16:46|SAGA execution commands|libshapes_lines
>>>>> "Convert Points to Line(s)" -POINTS /Users/jbogdani/qgis/points.shp
>>>>> -ORDER
>>>>> "cat1" -SEPARATE "cat2" -LINES
>>>>> /Users/jbogdani/sextante/tempdata/1333275406.0329.shp
>>>>> INFO|Sun Apr 01 2012 12:16:46|SAGA execution console
>>>>> output|/Users/jbogdani/sextante/saga_batch_job.sh: line 1: saga_cmd:
>>>>> command
>>>>> not found
>>>>> Julian Bogdani
>>>>> http://bradypus.net
>>>>> On 1 Apr 2012, at 12:09 , gene wrote:
>>>>>> I installed this plugin (and before the experimental 0.1 from
>>>>>> http://code.google.com/p/sextante/source/browse/#svn%2Ftrunk%2Fsoft%2Fbindings%2Fqgis-plugin
>>>>>> ) otherwise I could not say that it not works with SAGA or R.
>>>>>> View this message in context:
>>>>>> http://osgeo-org.1560.n6.nabble.com/Mac-OS-X-Sextante-and-other-plugins-or-the-forgotten-users-tp4676106p4676150.html
>>>>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
