[Qgis-user] sextante plugin on mac
John C. Tull jctull at gmail.com
Mon Apr 2 08:58:43 PDT 2012
On Apr 1, 2012, at 2:19 AM, Victor Olaya wrote:
>> but others complaint about python (e.g. sextante help, or
>> line intersections).
> Line intersection is fixed. The problem with help is that it calls the
> default application for opening the pdf manual. I prepared it to work
> on linux and windows...but not on mac, so basically it should be
> trying to open it like it does in linux, which I gess it is not
> working :(
Hi Victor,
What is your linux command? On OSX, a simple bash command of `open foo.pdf` will open the default pdf viewer. I'm not sure if that helps or not.
Regards,
John
