[Qgis-user] sextante plugin on mac
Victor Olaya volayaf at gmail.com
Mon Apr 2 09:10:29 PDT 2012
Perfect, that it what I said I was looking for, colllaboration from
the community. It is not necessary to actually code, but to help me
(or others) do things easily, in this case considering that I do not
know anything about OSX
Regards
El día 2 de abril de 2012 17:58, John C. Tull <jctull at gmail.com> escribió:
> On Apr 1, 2012, at 2:19 AM, Victor Olaya wrote:
>>> but others complaint about python (e.g. sextante help, or
>>> line intersections).
>> Line intersection is fixed. The problem with help is that it calls the
>> default application for opening the pdf manual. I prepared it to work
>> on linux and windows...but not on mac, so basically it should be
>> trying to open it like it does in linux, which I gess it is not
>> working :(
> Hi Victor,
> What is your linux command? On OSX, a simple bash command of `open foo.pdf` will open the default pdf viewer. I'm not sure if that helps or not.
> Regards,
> John
