[Qgis-user] gdaltools do not load when starting qgis
Giuseppe Sucameli brush.tyler at gmail.com
Tue Apr 3 08:01:10 PDT 2012
On Tue, Apr 3, 2012 at 10:34 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> I have problems starting QGIS 1.7.4 Wroclaw.
> GdalTools do not load and I get the following message below.
[[CUT]]
> ImportError: /usr/lib/python2.7/dist-packages/osgeo/_gdal.so: symbol VSIFTruncateL, version
> GDAL_1.8 not defined in file libgdal.so.1 with link time reference
seems your system uses python-gdal 1.8 (even though I see
you have python-gdal1.9 installed) and libgdal 1.9. See [1].
Regards.
[1] http://osgeo-org.1560.n6.nabble.com/Re-Lots-of-errors-at-starting-up-qgis-1-7-3-after-upgrade-of-libgdal1-to-1-9-td4368868.html
> but I have /usr/lib/libgdal1.8.0.so.1
> For reference:
> ~$ apt-show-versions | grep gdal
> gdal-bin/oneiric uptodate 1.9.0-2~exp5~oneiric1
> libgdal-dev/oneiric uptodate 1.9.0-2~exp5~oneiric1
> libgdal-ecw-src/oneiric uptodate 1.9.0-2~oneiric1
> libgdal-mrsid-src/oneiric uptodate 1.9.0-2~oneiric1
> libgdal1/oneiric uptodate 1.9.0-2~exp5~oneiric1
> libgdal1-1.7.0/oneiric uptodate 1.7.3-5ubuntu1
> libgdal1-1.8.0/oneiric uptodate 1.8.0-3~oneiric1
> libgdal1-1.8.0-grass/oneiric uptodate 1.8.0-2~oneiric1
> python-gdal/oneiric uptodate 1.9.0-2~exp5~oneiric1
> Cheers,
> Rainer
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys.
> (Germany)
> Centre of Excellence for Invasion Biology
> Stellenbosch University
> South Africa
> Tel :       +33 - (0)9 53 10 27 44
> Cell:       +33 - (0)6 85 62 59 98
> Fax :       +33 - (0)9 58 10 27 44
> Fax (D):    +49 - (0)3 21 21 25 22 44
> email:      Rainer at krugs.de
> Skype:      RMkrug
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.11 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAk96tgUACgkQoYgNqgF2egqavgCfbnKowebTpFHUr4xkrO3HtWwT
> R88AnRYxN4VhH89fTipoBdIJWBA0mvaE
> =9Ljx
> -----END PGP SIGNATURE-----
> Qgis-user mailing list
Giuseppe Sucameli
