SOLVED : [Qgis-user] gdaltools do not load when starting qgis
Rainer M Krug r.m.krug at gmail.com
Wed Apr 4 00:46:22 PDT 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 03/04/12 17:01, Giuseppe Sucameli wrote:
> Hi,
> On Tue, Apr 3, 2012 at 10:34 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
>> I have problems starting QGIS 1.7.4 Wroclaw.
>> GdalTools do not load and I get the following message below.
> [[CUT]]
>> ImportError: /usr/lib/python2.7/dist-packages/osgeo/_gdal.so: symbol VSIFTruncateL, version
>> GDAL_1.8 not defined in file libgdal.so.1 with link time reference
> seems your system uses python-gdal 1.8 (even though I see you have python-gdal1.9 installed)
> and libgdal 1.9. See [1].
True - that was the problem. Forced version of python-gdal to 1.7.3 and it is working now.
I remember having problems with gdaltools before because gdal versions - is there any way that
this can be made easier for the average user?
Cheers,
Rainer
> Regards.
> [1]
> http://osgeo-org.1560.n6.nabble.com/Re-Lots-of-errors-at-starting-up-qgis-1-7-3-after-upgrade-of-libgdal1-to-1-9-td4368868.html
>> but I have /usr/lib/libgdal1.8.0.so.1
>> For reference: ~$ apt-show-versions | grep gdal gdal-bin/oneiric uptodate
>> 1.9.0-2~exp5~oneiric1 libgdal-dev/oneiric uptodate 1.9.0-2~exp5~oneiric1
>> libgdal-ecw-src/oneiric uptodate 1.9.0-2~oneiric1 libgdal-mrsid-src/oneiric uptodate
>> 1.9.0-2~oneiric1 libgdal1/oneiric uptodate 1.9.0-2~exp5~oneiric1 libgdal1-1.7.0/oneiric
>> uptodate 1.7.3-5ubuntu1 libgdal1-1.8.0/oneiric uptodate 1.8.0-3~oneiric1
>> libgdal1-1.8.0-grass/oneiric uptodate 1.8.0-2~oneiric1 python-gdal/oneiric uptodate
>> Cheers,
>> Rainer
>> - - -- Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT),
>> Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology Stellenbosch University South Africa
>> Tel :       +33 - (0)9 53 10 27 44 Cell:       +33 - (0)6 85 62 59 98 Fax :       +33 - (0)9
>> 58 10 27 44
>> Fax (D):    +49 - (0)3 21 21 25 22 44
>> email:      Rainer at krugs.de
>> Skype:      RMkrug -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.11 (GNU/Linux) Comment:
>> Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>> iEYEARECAAYFAk96tgUACgkQoYgNqgF2egqavgCfbnKowebTpFHUr4xkrO3HtWwT
>> R88AnRYxN4VhH89fTipoBdIJWBA0mvaE =9Ljx -----END PGP SIGNATURE-----
>> _______________________________________________ Qgis-user mailing list
>> Qgis-user at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/qgis-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys.
(Germany)
South Africa
Fax :       +33 - (0)9 58 10 27 44
Skype:      RMkrug
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk97/E4ACgkQoYgNqgF2egoM5QCfTibNkZBVVmGOjy5UaR9VoGa/
Y9gAn3owv2V5Lrle/yKW/fj2TKraKefX
=1Zyv
