Re: [Qgis-user] about some ellipsoïdal distances : I fully agree . just may be better to use symbol rf (or something else) for inverse flattening ...
G. Allegri giohappy at gmail.com
Sat Apr 7 03:39:17 PDT 2012
You're right. I was right thinking about it yesterday while committing the
changes.
*f *is misleading, and it should be substituded by *rf* in my formula.
Thanks for having reported your measurements. They helped a lot to figure
out the bug ;)
giovanni
2012/4/6 blavet <didier.blavet at ird.fr>
> *Good evening*
> Of course thank you again i fully agree with what you found which is
> mathematically correct ,
>  it was not easy to find, and is essential for debugging the calculation
> of ellipsoîdal distances
> I just had a quick look at the code found at
> http://trac.osgeo.org/qgis/browser/trunk/qgis/src/core/qgsdistancearea.cpp#L540
> i'm not an informatician so i can just say few words
> inverse flattening seems correctly defined in line 148 as
> mInvFlattening = mSemiMajor / ( mSemiMajor - mSemiMinor )
> therefater the bug that you found could be in line 153 (and may be in
> some other lines of the code, i cannot say)
> Therafter, it is just a detail (and a convention) but
> just to try to help to avoid a potential confusion in the future code
> maintenance. ,
> about the letter "f" used in your message about "inverse flattening" i
> think that it would may be  better to use another letter than f  for
> designation of inverse flattening ... I say this   just because  in line
> 550 of the code found today at
> http://trac.osgeo.org/qgis/browser/trunk/qgis/src/core/qgsdistancearea.cpp#L540the letter f was already assigned as f = 1/mInvFlattening, indicating that
> letter f in this code is already reserved for ... flattening)
> So of course and again what you said is perfecly correct from a
> mathematical point of view (as long as you say, by convention,  that f =
> inverse flattening) ,
> Therefore the demonstration  would may be a bit clearer just with
> replacing this letter f by some other symbol or combination of symbols for
> the designation of inverse flattening
> (as this f is already used for something else in the code).
> Would it be possible for instance to use the symbolic combination *rf*,
> used in proj4  (for "reciprocal flattening" which is, as far as i know,  in
> english, equivalent to inverse flattening)
> then this would give, from what you found this morning , and with exactly
> the same meaning that what you said :
> *In Qgis the semi-minor axis of the ellipsoid is calculated with:
>      b = a - (rf/a)
>      where
>      b = semi-minor axis
>      a = semi-major axis
>      rf =  inverse flattening (= "reciprocal flattening" = a/(a-b)  )
>      while it should be:
>      b = a - (a/rf)*
> therefore, this rf symbol would also fit with the +rf proj4 parameter
> defined as
> "+rf       reciprocal of the ellipsoid flattening term (e.g. 298)"
> (also in proj4 +f is used for flattening
> +f         Flattening of the ellipsoid (often presented as an inverse,
> e.g. 1/298)
> (by the way , I guess, however, that the adjective reciprocal for
> "reciprocal numbers" can have also some other meanings for the pure
> mathematicians ..
> ... Therefore it would also be possible to use another symbol for inverse
> flattening than rf  (but preferentially not f (:-))
> *Thank you again
> Best regards
> Le 06/04/2012 14:15, G. Allegri a écrit :
> Not at all.
> The change has already been committed to the development version.
>  giovanni
>>  Thank you very much for this very fast and efficient diagnosis
>> Best regards
>> Didier Blavet
>> Le 06/04/2012 12:01, G. Allegri a écrit :
>> Probably I've found the bug.
>>  b = a - (f/a)
>>  where
>> b = semi-minor axis
>> a = semi-majot axis
>>  while it should be:
>>  b = a - (a/f)
>>  In Qgis the WGS84 semi-minor axis is 6378136,xxx
>> while it should be 6356752.xxx
>>  giovanni
>> 2012/4/6 G. Allegri <giohappy at gmail.com>
>>> AFAICS, the Qgis formula [1] to calculate distances on ellipssoid is
>>> Vincenty's.
>>> I've reproduced it for the first set of points and I can confirm tha
>>> QGis gives 540.9973919726176 m
>>>  The online Vincenty calculator [2] gives 540.045 m
>>>  I suppose it's a rounding issue.
>>> I will investigate it more...
>>>  giovanni
>>>  [1]
>>> [2] http://www.movable-type.co.uk/scripts/latlong-vincenty.html
>>>>  Dear QGis Developpers and Users
>>>> _______________________________________________________________________________________
>>>> *Didier B**lavet*
>>>> Institut de Recherche pour le Développement - IRD (http://www.ird.fr)
>>>> UMR Eco&Sols - Ecologie Fonctionnelle & Biogéochimie des Sols &
>>>> Agroécosystèmes
>>>> (Montpellier SupAgro-CIRAD-INRA-IRD) (
>>>> http://www.montpellier.inra.fr/ecosols)
>>>> Bâtiment 12, 2 place Viala, F-34060 Montpellier Cedex 2 , France
>>>> Tel bureau : +33 (0)4 99 61 21 33
>>>> Secrétariat : +33 (0)4 99 61 21 01 / Fax : +33 (0)4 99 61 21 19
>>>> Courriel : didier.blavet at ird.fr
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> *Didier B**lavet*
>> Agroécosystèmes
> *Didier B**lavet*
> Agroécosystèmes
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120407/9811a1db/attachment.html>
