Re: [Qgis-user] about some ellipsoïdal distances
G. Allegri giohappy at gmail.com
Fri Apr 6 05:15:39 PDT 2012
Not at all.
The change has already been committed to the development version.
giovanni
2012/4/6 blavet <didier.blavet at ird.fr>
> Thank you very much for this very fast and efficient diagnosis
> Best regards
> Didier Blavet
> Le 06/04/2012 12:01, G. Allegri a écrit :
> Probably I've found the bug.
> In Qgis the semi-minor axis of the ellipsoid is calculated with:
>  b = a - (f/a)
>  where
> b = semi-minor axis
> a = semi-majot axis
> f = inverse flattening
>  while it should be:
>  b = a - (a/f)
>  In Qgis the WGS84 semi-minor axis is 6378136,xxx
> while it should be 6356752.xxx
>  giovanni
> 2012/4/6 G. Allegri <giohappy at gmail.com>
>> AFAICS, the Qgis formula [1] to calculate distances on ellipssoid is
>> Vincenty's.
>> I've reproduced it for the first set of points and I can confirm tha QGis
>> gives 540.9973919726176 m
>>  The online Vincenty calculator [2] gives 540.045 m
>>  I suppose it's a rounding issue.
>> I will investigate it more...
>>  giovanni
>>  [1]
>> http://trac.osgeo.org/qgis/browser/trunk/qgis/src/core/qgsdistancearea.cpp#L540
>> [2] http://www.movable-type.co.uk/scripts/latlong-vincenty.html
>>>  Dear QGis Developpers and Users
>>> _______________________________________________________________________________________
>>> *Didier B**lavet*
>>> Institut de Recherche pour le Développement - IRD (http://www.ird.fr)
>>> UMR Eco&Sols - Ecologie Fonctionnelle & Biogéochimie des Sols &
>>> Agroécosystèmes
>>> (Montpellier SupAgro-CIRAD-INRA-IRD) (
>>> http://www.montpellier.inra.fr/ecosols)
>>> Bâtiment 12, 2 place Viala, F-34060 Montpellier Cedex 2 , France
>>> Tel bureau : +33 (0)4 99 61 21 33
>>> Secrétariat : +33 (0)4 99 61 21 01 / Fax : +33 (0)4 99 61 21 19
>>> Courriel : didier.blavet at ird.fr
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> *Didier B**lavet*
> Agroécosystèmes
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120406/f59fec7e/attachment.html>
