[Qgis-user] RE: Georeferencer not loading
magerlin MAP at ramboll.dk
Wed Apr 25 01:40:53 PDT 2012
Hi
Just checked - with the georeferencer plugin window open I can with no
problem click on another plugin and launch it with its window
automatically active, so I do not think your observations proves, that
Georeferencer is not loaded.
Regards Morten
[mailto:ml-node+s1560n4915997h46 at n6.nabble.com]
Sent: 25. april 2012 10:35
To: Morten Agerlin Petersen (MAP)
Subject: Re: Georeferencer not loading
Thanks for the suggestion Morten,
Unfortunately when I click on the Georeferencer icon the main QGIS
window remains selected. Clicking on any other plugin automatically
launches it and the plugin window is automatically active. Therefore I
know that the Georeferencer is not loading.
On 25 April 2012 18:27, magerlin [via OSGeo.org] <[hidden email]> wrote:
Hi
I have sometimes experienced the same - nothing seems to happen when I
select the georeferencer.
But the fact is that something happens, but the opened Georeferencer
window is hidden somewhere.
One case is if I have used two displays and put Qgis on the one and the
Georeferencer window on the other. If I close Qgis from there and later
opens Qgis using only one display, then the Georeferencer window will
sometimes seems to be missing (but it is as a matter of fact shown on a
non existing second display) - this is a Windows issue and not Qgis.
The best solution is to start Qgis using two displays and move the
Georeferenser window to your main screen before closing Qgis down.
If that is no possible then try using the combination of the ALT+Space
keys. This opens a small window menu with the possibilities to Move
(used the arrow keys after this selection), Restore or Maximize windows
- I think I have sometimes used this as a solution to get it back on my
main display.
Hope this can help...
Regards Morten
Qgis 1.7.4 Stand alone installer in Win7 64 bit
If you reply to this email, your message will be added to the discussion
below:
http://osgeo-org.1560.n6.nabble.com/Georeferencer-not-loading-tp4915363p
4915981.html
To unsubscribe from Georeferencer not loading, click here.
NAML
<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macr
o_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespac
es.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.w
eb.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemai
l.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%
3Aemail.naml>
below:
4915997.html
<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsu
bscribe_by_code&node=4915363&code=TUFQQHJhbWJvbGwuZGt8NDkxNTM2M3wtMTI3MT
QwNTYxOA==> .
NAML
3Aemail.naml>
Regards Morten
View this message in context: http://osgeo-org.1560.n6.nabble.com/Georeferencer-not-loading-tp4915363p4916006.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120425/872920c4/attachment.html>
