[Qgis-user] Re: Delete columns of a .shp file with GDAL/OGR 1.9.0
iomeneandrei aborruso at tin.it
Wed Apr 25 09:36:56 PDT 2012
Ciao Giovanni,
thank you.
Giovanni Manghi-2 wrote
> it was never a QGIS issue as it uses OGR to handle vectors: native
> column deleting is available only since gdal/ogr 1.9, now used by qgis
> 1.7.4. Any other software that allows deleting columns and uses gdal/ogr
> < 1.9 has an internal workaround. In QGIS the tool that allowed to do
> that (plus reordering and renaming columns) is the table manager plugin.
> If Andrea uses qgis 1.7.4 compiled against gdal/ogr 1.9 and cannot
> delete columns the issue is eleswhere.
In QGIS 1.7.4 you have the delete column button in the standard interface. I
thought that since I have gdal/ogr 1.9, I could have used this standard
button.
Is it possible to use it in some other QGIS version?
I'm able to delete columns using table manager, without save a copy of the
original shp file.
cheers
View this message in context: http://osgeo-org.1560.n6.nabble.com/Delete-columns-of-a-shp-file-with-GDAL-OGR-1-9-0-tp4916642p4917218.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
