[Qgis-user] startup problem qgis master
Paulo van Breugel p.vanbreugel at gmail.com
Wed Aug 1 02:17:59 PDT 2012
Just to let you know, and to close this thread, that after restarting my
computer this morning, everything works. So writing the lib path th a
config file in /etc/ld.so.conf.d works. Not sure why it only worked this
morning after restart though.
Thanks Tim for your help, much appreciated.
On Tue, Jul 31, 2012 at 4:35 PM, Paulo van Breugel
<p.vanbreugel at gmail.com>wrote:
>  I didn't, but doing so does make it run.
> What I do not understand is that I created a config file (qgis_dev.conf)
> in /etc/ld.so.conf.d (and run sudo ldconfig afterwards), which I though
> should take care of defining the path. I'll check if I did not do anything
> wrong there.
> Thanks for your help
> Paulo
> On 07/31/2012 03:51 PM, Tim Sutton wrote:
> Hi
> On Tue, Jul 31, 2012 at 3:05 PM, Paulo van Breugel<p.vanbreugel at gmail.com> <p.vanbreugel at gmail.com> wrote:
>  Hi, I used ccmake with CMAKE_INSTALL_PREFIX: /usr/local/qgis_dev, if that is
> what you mean (I have qgis 1.8 installed in /usr/local/qgis18, if that is of
> any importance)?
> I then tried to run it from within the /usr/local/qgis_dev/bin with ./qgis,
> giving the reported error message.
>  Did you do this before running?
> export LD_LIBRARY_PATH=/usr/local/qgis_dev/lib
> /usr/local/qgis_dev/bin/qgis
> Tim
>  Cheers
> Paulo
> On Tue, Jul 31, 2012 at 2:54 PM, Tim Sutton <lists at linfiniti.com> <lists at linfiniti.com> wrote:
>  Hi
> On Tue, Jul 31, 2012 at 2:40 PM, Paulo van Breugel<p.vanbreugel at gmail.com> <p.vanbreugel at gmail.com> wrote:
>  I have compiled / build QGIS master branch downloaded from the QGIS
> download
> page (qgis-Quantum-GIS-final-1_8_0-601-gc859799.tar.gz) on Ubuntu 12.04.
> No
> error message during building, but when trying to run qgis, I am getting
> the
> following error message:
> ./qgis: symbol lookup error: ./qgis: undefined symbol:
> _ZN14QgsRasterLayer20CUMULATIVE_CUT_UPPERE
>  What install prefix did you use?
> export LD_LIBRARY_PATH=<install prefix>/lib
> <install prefix>/bin/qgis
> Regards
> Tim
>  Any idea how to solve this?
> Thanks
> Paulo
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120801/1efe4e64/attachment.html>
