[Qgis-user] startup problem qgis master
Tim Sutton
lists at linfiniti.com
Wed Aug 1 13:33:06 PDT 2012
Hi
On Wed, Aug 1, 2012 at 11:17 AM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> Just to let you know, and to close this thread, that after restarting my
> computer this morning, everything works. So writing the lib path th a config
> file in /etc/ld.so.conf.d works. Not sure why it only worked this morning
> after restart though.
> Thanks Tim for your help, much appreciated.
No problem.
Tim
> On Tue, Jul 31, 2012 at 4:35 PM, Paulo van Breugel <p.vanbreugel at gmail.com>
> wrote:
>> I didn't, but doing so does make it run.
>> What I do not understand is that I created a config file (qgis_dev.conf)
>> in /etc/ld.so.conf.d (and run sudo ldconfig afterwards), which I though
>> should take care of defining the path. I'll check if I did not do anything
>> wrong there.
>> Thanks for your help
>> Paulo
>> On 07/31/2012 03:51 PM, Tim Sutton wrote:
>> Hi
>> On Tue, Jul 31, 2012 at 3:05 PM, Paulo van Breugel
>> Hi, I used ccmake with CMAKE_INSTALL_PREFIX: /usr/local/qgis_dev, if that
>> is
>> what you mean (I have qgis 1.8 installed in /usr/local/qgis18, if that is
>> of
>> any importance)?
>> I then tried to run it from within the /usr/local/qgis_dev/bin with
>> ./qgis,
>> giving the reported error message.
>> Did you do this before running?
>> export LD_LIBRARY_PATH=/usr/local/qgis_dev/lib
>> /usr/local/qgis_dev/bin/qgis
>> Tim
>> Cheers
>> Paulo
>> On Tue, Jul 31, 2012 at 2:54 PM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi
>> On Tue, Jul 31, 2012 at 2:40 PM, Paulo van Breugel
>> I have compiled / build QGIS master branch downloaded from the QGIS
>> download
>> page (qgis-Quantum-GIS-final-1_8_0-601-gc859799.tar.gz) on Ubuntu 12.04.
>> No
>> error message during building, but when trying to run qgis, I am getting
>> the
>> following error message:
>> ./qgis: symbol lookup error: ./qgis: undefined symbol:
>> _ZN14QgsRasterLayer20CUMULATIVE_CUT_UPPERE
>> What install prefix did you use?
>> export LD_LIBRARY_PATH=<install prefix>/lib
>> <install prefix>/bin/qgis
>> Regards
>> Tim
>> Any idea how to solve this?
>> Thanks
>> Paulo
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>> * QGIS programming and support services
>> * Mapserver and PostGIS based hosting plans
>> * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
Skype: timlinux
