[Qgis-user] Incorrect placement of ABC labels
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Wed Aug 1 02:59:38 PDT 2012
Hi
I guess that the labeling engine does not calculate an interior point but a centroid ("center of mass") that can be outside the polygon.
Regards
Stefan
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Im
> Auftrag von magerlin
> Gesendet: Mittwoch, 1. August 2012 11:19
> An: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] Incorrect placement of ABC labels
> Werner Macho-2 wrote
> > Hi!
> > I don't know if I am right but .. isn't the placement of labels done
> > with it's own engine where you can tell if you want to have it right
> > above /left below (....) the point depending on available space?
> > Probably you switched on some of these possibilities and it selects
> > one of those places which fits best for every centroid point ..
> > Just a thought without having tested
> > kind regards
> > Werner
> Yes you can choose different sort of placement but I have selected "Over centroid"
> which removes a lot of the other placement adjustment possibilities.
> It is possible ("for debugging purposes") to make ABC show all label candidates but
> only one is shown when "over centroid" is selected.
> Regards Morten
> Qgis 1.8.0 Stand alone installer in Win7 64 bit
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Incorrect-
> placement-of-ABC-labels-tp4992143p4992346.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
