[Qgis-user] Incorrect placement of ABC labels
magerlin MAP at ramboll.dk
Wed Aug 1 02:18:40 PDT 2012
Werner Macho-2 wrote
> Hi!
> I don't know if I am right but .. isn't the placement of labels done
> with it's own engine where you can tell if you want to have it right
> above /left below (....) the point depending on available space?
> Probably you switched on some of these possibilities and it selects one
> of those places which fits best for every centroid point ..
> Just a thought without having tested
> kind regards
> Werner
Yes you can choose different sort of placement but I have selected "Over
centroid" which removes a lot of the other placement adjustment
possibilities.
It is possible ("for debugging purposes") to make ABC show all label
candidates but only one is shown when "over centroid" is selected.
Regards Morten
Qgis 1.8.0 Stand alone installer in Win7 64 bit
View this message in context: http://osgeo-org.1560.n6.nabble.com/Incorrect-placement-of-ABC-labels-tp4992143p4992346.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
