[Qgis-user] Problem with Managing Plugins with qgis 1.8
Sergio Vignali vignalisergio30 at gmail.com
Fri Aug 3 00:52:23 PDT 2012
It's something like this:
Unpack (unzip) the plugin failed. Probably the file is corrupted or does
not exist in the repository. Check the write permissions of the folder of
plugins:
/ home / sergio / .qgis / / python / plugins "
Sergio
2012/8/3 Noli Sicad <nsicad at gmail.com>
> You have to translate this message into English if want help.
> Noli
> On 8/3/12, Sergio Vignali <vignalisergio30 at gmail.com> wrote:
> > Thanks to all, but I don't be able to install any plugins
> > I get again this message
> > "Scompattazione (unzip) del plugin non riuscita. Probabilmente
> l'archivio รจ
> > corrotto o non esiste nel repository. Controllare i permessi in scrittura
> > della cartella dei plugin:
> > /home/sergio/.qgis//python/plugins"
> > Sergio
> > 2012/8/3 Ivan Mincik <ivan.mincik at gmail.com>
> >> "Add 3rd party repositories" button was removed in 1.8. See [1].
> >> 1 -
> http://hub.qgis.org/projects/quantum-gis/wiki/Python_Plugin_Repositories
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120803/a3a60c6a/attachment.html>
