[Qgis-user] Problem with Managing Plugins with qgis 1.8
alex thezal at gmail.com
Fri Aug 3 01:37:35 PDT 2012
Hi Sergio,
it seem you don't own  .qgis directory in your home dir:
type in a terminal window (Ctrl+Alt+T keyboard shortcut ...)
ls -la /home/sergio/ | grep .qgis
and see  results.
In case, to change the owner of the .qgis dir type in a terminal window:
sudo chown -R sergio:sergio /home/sergio/.qgis
and you will prompt for your password.
I had same problem in Ubuntu 12.04 and QGis 1.8 and .qgis dir in my
home are owned by root: typing this command solved the situation.
Best Regards
Alessandro
On 3 August 2012 09:52, Sergio Vignali <vignalisergio30 at gmail.com> wrote:
> It's something like this:
> Unpack (unzip) the plugin failed. Probably the file is corrupted or does not
> exist in the repository. Check the write permissions of the folder of
> plugins:
> / home / sergio / .qgis / / python / plugins "
> Sergio
> 2012/8/3 Noli Sicad <nsicad at gmail.com>
>> You have to translate this message into English if want help.
>> Noli
>> On 8/3/12, Sergio Vignali <vignalisergio30 at gmail.com> wrote:
>> > Thanks to all, but I don't be able to install any plugins
>> > I get again this message
>> > "Scompattazione (unzip) del plugin non riuscita. Probabilmente
>> > l'archivio รจ
>> > corrotto o non esiste nel repository. Controllare i permessi in
>> > scrittura
>> > della cartella dei plugin:
>> > /home/sergio/.qgis//python/plugins"
>> > Sergio
>> > 2012/8/3 Ivan Mincik <ivan.mincik at gmail.com>
>> >> "Add 3rd party repositories" button was removed in 1.8. See [1].
>> >> 1 -
>> >> http://hub.qgis.org/projects/quantum-gis/wiki/Python_Plugin_Repositories
> Qgis-user mailing list
