[Qgis-user] Problem with Managing Plugins with qgis 1.8
Robin Cura robin.cura at gmail.com
Fri Aug 3 01:40:18 PDT 2012
Did you give the writing permission as requested ?
sudo chmod -R 777 /home/sergio/.qgis/python/plugins
Robin
2012/8/3 Sergio Vignali <vignalisergio30 at gmail.com>
> It's something like this:
> Unpack (unzip) the plugin failed. Probably the file is corrupted or does
> not exist in the repository. Check the write permissions of the folder of
> plugins:
> / home / sergio / .qgis / / python / plugins "
> Sergio
> 2012/8/3 Noli Sicad <nsicad at gmail.com>
>> You have to translate this message into English if want help.
>> Noli
>> On 8/3/12, Sergio Vignali <vignalisergio30 at gmail.com> wrote:
>> > Thanks to all, but I don't be able to install any plugins
>> > I get again this message
>> > "Scompattazione (unzip) del plugin non riuscita. Probabilmente
>> l'archivio è
>> > corrotto o non esiste nel repository. Controllare i permessi in
>> scrittura
>> > della cartella dei plugin:
>> > /home/sergio/.qgis//python/plugins"
>> > Sergio
>> > 2012/8/3 Ivan Mincik <ivan.mincik at gmail.com>
>> >> "Add 3rd party repositories" button was removed in 1.8. See [1].
>> >> 1 -
>> http://hub.qgis.org/projects/quantum-gis/wiki/Python_Plugin_Repositories
> Qgis-user mailing list
Robin Cura
Ingénieur d'Étude à l'UMR Géographie-cités
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120803/674c3b61/attachment.html>
