[Qgis-user] Problem with Managing Plugins with qgis 1.8
Sergio Vignali vignalisergio30 at gmail.com
Fri Aug 3 01:45:53 PDT 2012
I have the same problem!
I have just controlled the folder,
into / home / sergio / .qgis I have only gdal_pam folder and
python / plugins one doesn't exist.
Must I create the folders?
2012/8/3 Noli Sicad <nsicad at gmail.com>
> Try to use sudo.
> e.g.
> sudo nautilus
> then you can just drop anything in that plugins folder.
> Noli
> On 8/3/12, Sergio Vignali <vignalisergio30 at gmail.com> wrote:
> > It's something like this:
> > Unpack (unzip) the plugin failed. Probably the file is corrupted or does
> > not exist in the repository. Check the write permissions of the folder of
> > plugins:
> > / home / sergio / .qgis / / python / plugins "
> > Sergio
> >> You have to translate this message into English if want help.
> >> Noli
> >> > Thanks to all, but I don't be able to install any plugins
> >> > I get again this message
> >> > "Scompattazione (unzip) del plugin non riuscita. Probabilmente
> >> l'archivio รจ
> >> > corrotto o non esiste nel repository. Controllare i permessi in
> >> > scrittura
> >> > della cartella dei plugin:
> >> > /home/sergio/.qgis//python/plugins"
> >> > Sergio
> >> > 2012/8/3 Ivan Mincik <ivan.mincik at gmail.com>
> >> >> "Add 3rd party repositories" button was removed in 1.8. See [1].
> >> >> 1 -
> http://hub.qgis.org/projects/quantum-gis/wiki/Python_Plugin_Repositories
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120803/16666833/attachment.html>
