[Qgis-user] GPS interface
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Mon Aug 6 09:26:17 PDT 2012
Christy -
IAFK , You can upload a GPX file directly to a Garmin 62 GPS unit. So
your problem is how to convert your shapefile to a GPX file:
1. Right click on your shapefile layer in the "Layers" dialog. A menu
will be shown with several choices.
2. Chose "Save As" from the right click - menu. A new dialog "Save
vector layer as.." will be shown.
3. In the new dialog:
- Select "GPS eXchange Format [GPX] as Format
- Select "Selected CRS" in "CRS" and - using the "Browse" button -
select "EPSG:4326" as the CRS (projection). It is important that you
choose this projection.
- In the "Data source" box you probably have to write
"GPX_USE_EXTENSIONS=YES" (Without the "")
- Select a filename for the new GPX file.
4. Push the "OK" button to generate the GPX file. This file can be
copied to the GPS unit.
Regards
Bo Victor Thomsen
Aestas-GIS
Denmark
Den 06-08-2012 08:16, Christy Ihlo skrev:
> S u
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120806/b961f787/attachment.html>
