[Qgis-user] GPS interface
werner at macho.cc
werner at macho.cc
Mon Aug 6 23:27:35 PDT 2012
Hi!
Depending on which Operating System you are using I suggest either to
use the tool coming with you Garmin (MapSource?)
Or in the OpenSource World there is a nice program which works
perfectly with Garmin. It is called QtLandkarteGT [1].
QGIS is not a "GPS"-Managing Program - it is able to connect to
GPS-devices but only for the purpose of downloading data or displaying
actual position.
If you want to upload something to your device you have to use a format
which your device is able to understand and use a program that is able
to upload to your device.
Hope that helps
kind regards
Werner
[1] http://www.qlandkarte.org/
Am 06.08.2012 08:16, schrieb Christy Ihlo:
> Hello All,
> I would like to upload shapefiles through QGIS into my Garmin 62 GPS
> unit. I did a little research online and it appears that QGIS can
> only
> upload files in the gpx format (please correct me if I'm wrong!).
> Does
> anyone have any suggestions on alternative ways to accomplish this
> task?
> Thank you!
> Christy Ihlo
> Intern, African People & Wildlife Fund
> Noloholo Environmental Center
> Loibor Siret, Tanzania
> christy.ihlo at duke.edu [1]
> Links:
> [1] mailto:christy.ihlo at duke.edu
