[Qgis-user] GPS interface
Filipe Dias filipesdias at gmail.com
Tue Aug 7 00:40:00 PDT 2012
You can also try DNRGPS, which is also open source and very works very well
with Garmin GPS machines.
http://www.dnr.state.mn.us/mis/gis/DNRGPS/DNRGPS.html
On Tue, Aug 7, 2012 at 7:27 AM, <werner at macho.cc> wrote:
> Hi!
> Depending on which Operating System you are using I suggest either to use
> the tool coming with you Garmin (MapSource?)
> Or in the OpenSource World there is a nice program which works perfectly
> with Garmin. It is called QtLandkarteGT [1].
> QGIS is not a "GPS"-Managing Program - it is able to connect to
> GPS-devices but only for the purpose of downloading data or displaying
> actual position.
> If you want to upload something to your device you have to use a format
> which your device is able to understand and use a program that is able to
> upload to your device.
> Hope that helps
> kind regards
> Werner
> [1] http://www.qlandkarte.org/
> Am 06.08.2012 08:16, schrieb Christy Ihlo:
>> Hello All,
>>  I would like to upload shapefiles through QGIS into my Garmin 62 GPS
>> unit. I did a little research online and it appears that QGIS can only
>> upload files in the gpx format (please correct me if I'm wrong!). Does
>> anyone have any suggestions on alternative ways to accomplish this
>> task?
>>  Thank you!
>>  Christy Ihlo
>>  Intern, African People & Wildlife Fund
>>  Noloholo Environmental Center
>>  Loibor Siret, Tanzania
>>  christy.ihlo at duke.edu [1]
>> Links:
>> [1] mailto:christy.ihlo at duke.edu
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120807/5dd94908/attachment.html>
