[Qgis-user] Python-gdal missing
Agustin Lobo
alobolistas at gmail.com
Sat Aug 11 04:43:22 PDT 2012
Luis,
I'm probably not a reliable source for this, but I would rename those
files for which you the equivalent newer files are
in /usr/lib. For example rename
sudo mv /usr/local/lib/libgdal.a /usr/local/lib/libgdal.a_old
Then restart qgis.
Agus
2012/8/10 Luís de Sousa <luis.a.de.sousa at gmail.com>:
> Hi Augustin, that seems a sensible solution, QGis should be using the latest
> version of python-gdal.
> Nonetheless, I can't tell exactly what should I remove:
> $ ls -la /usr/local/lib/libgdal*
> -rw-r--r-- 1 root root 88673692 Nov 30 2011 /usr/local/lib/libgdal.a
> -rwxr-xr-x 1 root root 1152 Nov 30 2011 /usr/local/lib/libgdal.la
> lrwxrwxrwx 1 root root 17 Nov 30 2011 /usr/local/lib/libgdal.so ->
> libgdal.so.1.15.1
> lrwxrwxrwx 1 root root 17 Nov 30 2011 /usr/local/lib/libgdal.so.1 ->
> libgdal.so.1.15.1
> -rwxr-xr-x 1 root root 39920419 Nov 30 2011
> /usr/local/lib/libgdal.so.1.15.1
> Should I move it all way?
> Thank you,
> Luís
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Python-gdal-missing-tp4982586p4994442.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
