[Qgis-user] Python-gdal missing
Etienne Tourigny
etourigny.dev at gmail.com
Sat Aug 11 05:00:15 PDT 2012
Why do you have these files in /usr/local/lib? They are mote probably
not installed by the package manager!
Don't mix custom installs with apt packages, unless you know what
you're doing. This can lead to problems if you have different libgdal
versions installed. You can remove those *libgdal* in /usr/local/lib
On Fri, Aug 10, 2012 at 12:18 PM, Luís de Sousa
<luis.a.de.sousa at gmail.com> wrote:
> Hi Augustin, that seems a sensible solution, QGis should be using the latest
> version of python-gdal.
> Nonetheless, I can't tell exactly what should I remove:
> $ ls -la /usr/local/lib/libgdal*
> -rw-r--r-- 1 root root 88673692 Nov 30 2011 /usr/local/lib/libgdal.a
> -rwxr-xr-x 1 root root 1152 Nov 30 2011 /usr/local/lib/libgdal.la
> lrwxrwxrwx 1 root root 17 Nov 30 2011 /usr/local/lib/libgdal.so ->
> libgdal.so.1.15.1
> lrwxrwxrwx 1 root root 17 Nov 30 2011 /usr/local/lib/libgdal.so.1 ->
> libgdal.so.1.15.1
> -rwxr-xr-x 1 root root 39920419 Nov 30 2011
> /usr/local/lib/libgdal.so.1.15.1
> Should I move it all way?
> Thank you,
> Luís
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Python-gdal-missing-tp4982586p4994442.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
