[Qgis-user] Python-gdal missing
Agustin Lobo alobolistas at gmail.com
Sat Aug 11 08:27:46 PDT 2012
Perhaps at some point a qgis installation was puting the files there, because
we are several ubuntu users with that problem. Or perhaps we all made
the same error,
who knows. The fact is that those files must be renamed or deleted
from /usr/local/lib because
they interfere with the correct ones in /usr/lib
Agus
2012/8/11 Etienne Tourigny <etourigny.dev at gmail.com>:
> Why do you have these files in /usr/local/lib?  They are mote probably
> not installed by the package manager!
> Don't mix custom installs with apt packages, unless you know what
> you're doing. This can lead to problems if you have different libgdal
> versions installed. You can remove those *libgdal* in /usr/local/lib
> On Fri, Aug 10, 2012 at 12:18 PM, Luís de Sousa
> <luis.a.de.sousa at gmail.com> wrote:
>> Hi Augustin, that seems a sensible solution, QGis should be using the latest
>> version of python-gdal.
>> Nonetheless, I can't tell exactly what should I remove:
>> $ ls -la /usr/local/lib/libgdal*
>> -rw-r--r-- 1 root root 88673692 Nov 30  2011 /usr/local/lib/libgdal.a
>> -rwxr-xr-x 1 root root     1152 Nov 30  2011 /usr/local/lib/libgdal.la
>> lrwxrwxrwx 1 root root       17 Nov 30  2011 /usr/local/lib/libgdal.so ->
>> libgdal.so.1.15.1
>> lrwxrwxrwx 1 root root       17 Nov 30  2011 /usr/local/lib/libgdal.so.1 ->
>> libgdal.so.1.15.1
>> -rwxr-xr-x 1 root root 39920419 Nov 30  2011
>> /usr/local/lib/libgdal.so.1.15.1
>> Should I move it all way?
>> Thank you,
>> Luís
>> View this message in context: http://osgeo-org.1560.n6.nabble.com/Python-gdal-missing-tp4982586p4994442.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
