[Qgis-user] manageR doesn't work well
Eelke Folmer
e.o.folmer at gmail.com
Sat Aug 11 13:34:42 PDT 2012
I realize this is an old thread. I am getting some files to load nicely
into manageR but not others (which I can load directly using readOGR).
Same error as reported below. I find manageR extremely useful when it
works and it would be nice if it would always work.
OS linux mint
R 2.15.1
QGIS 1.8
Are there fixes/workarounds?
Thanks,
Eelke
> I have tested manageR on Ubuntu Gnome with QGIS 1.6 and R 2.11.1 and now the same shapefile that I was testing can be loaded. Now, I can perform some analysis on it. Is it because I was on Windows 7 that manageR was not working?
> I still have an issue with manageR on Ubuntu. I cant load the shapefile with the option Import layer from canvas, and receive this error message:
> Error in `[.data.frame`(data, match.ID[1]) : undefined columns selected
> When I load the data with the option Import layer attribute it seems to work. Someone have an idea why the first option is not working? Anybody has successfully used manageR in a Windows 7 environment?
> Thank you for your help,
> Maxime
