[Qgis-user] Black border in raster files
Giovanni Manghi giovanni.manghi at faunalia.pt
Sun Aug 12 00:32:28 PDT 2012
Dear Manuel,
in the raster properties choose "stretch and clip to min/max" (in the
contrast enhancement option) to remove the black "frame". Unfortunately
it will work only for the grayscale color ramp, as with the others you
will hit a known issue that affects the transparency of nulls values (or
values defined as null). Hopefully this issue will be fixed in the dev
version of QGIS as the rasters are being overhauled.
cheers
-- Giovanni --
On Sat, 2012-08-11 at 10:21 -0600, Manuel Spínola wrote:
> Sure Giovanni.
> Best,
> Manuel
> 2012/8/11 Giovanni Manghi <giovanni.manghi at faunalia.pt>
>         > Any other suggestion?
>         can you share the data?
> Manuel Spínola, Ph.D.
> Instituto Internacional en Conservación y Manejo de Vida Silvestre
> Universidad Nacional
> Apartado 1350-3000
> Heredia
> COSTA RICA
> mspinola at una.ac.cr
> mspinola10 at gmail.com
> Teléfono: (506) 2277-3598
> Fax: (506) 2237-7036
> Personal website: Lobito de río
> Institutional website: ICOMVIS
