[Qgis-user] Black border in raster files
Manuel Spínola mspinola10 at gmail.com
Sun Aug 12 07:56:34 PDT 2012
Thank you very much Giovanni.  As you said, that works only with grayscale.
 I hope in the future is also implemented for colormap.
Best,
Manuel
2012/8/12 Giovanni Manghi <giovanni.manghi at faunalia.pt>
> Dear Manuel,
> in the raster properties choose "stretch and clip to min/max" (in the
> contrast enhancement option) to remove the black "frame". Unfortunately
> it will work only for the grayscale color ramp, as with the others you
> will hit a known issue that affects the transparency of nulls values (or
> values defined as null). Hopefully this issue will be fixed in the dev
> version of QGIS as the rasters are being overhauled.
> cheers
> -- Giovanni --
> On Sat, 2012-08-11 at 10:21 -0600, Manuel Spínola wrote:
> > Sure Giovanni.
> > Best,
> > Manuel
> > 2012/8/11 Giovanni Manghi <giovanni.manghi at faunalia.pt>
> >         > Any other suggestion?
> >         can you share the data?
> > Manuel Spínola, Ph.D.
> > Instituto Internacional en Conservación y Manejo de Vida Silvestre
> > Universidad Nacional
> > Apartado 1350-3000
> > Heredia
> > COSTA RICA
> > mspinola at una.ac.cr
> > Teléfono: (506) 2277-3598
> > Fax: (506) 2237-7036
> > Personal website: Lobito de río
> > Institutional website: ICOMVIS
*Manuel Spínola, Ph.D.*
Apartado 1350-3000
Heredia
COSTA RICA
Personal website: Lobito de río <https://sites.google.com/site/lobitoderio/>
Institutional website: ICOMVIS <http://www.icomvis.una.ac.cr/>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120812/6b35627a/attachment.html>
