[Qgis-user] random locations sample from the actual map
richard burcher drownedfrog at gmail.com
Wed Aug 15 06:41:15 PDT 2012
Hi Chathura,
For vector data try the fTools. Look under Vector -- Research Tools, there
are several ie Random Selection & Random Selection within subsets. This
would do for selecting already present polygon/point type features & export
selected layer from table of contents as a new layer.
To select only a range of coordinates (point based data) you can add the x &
y columns to attribute table. select layer for edit, add column of type real
(remember to set precision to > 2) & from Geometry group in Function list
window select $x or $y. Save & stop editing, you may notice that the columns
go null -- this is a bug (i'm using 1.8 windows 7), close & reopen attribute
table. You can now use the query builder to filter out a range of values,
export selection & apply the fTools discussed above.
For more advanced options I would look at the mangeR plugin.
Plugins of interest:
Point Sampling tool
Spatial Data Analysis for point pattern -- very extensive functionality
Cheers,
Richard
View this message in context: http://osgeo-org.1560.n6.nabble.com/random-locations-sample-from-the-actual-map-tp4995315p4995384.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
