[Qgis-user] Transparency for vector layer
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Wed Aug 15 06:44:08 PDT 2012
I know you get set a vector layer's transparency if it is symbolised using
a "single Symbol", however I can't seem to find any way to make
"Categorized" or "Graduated" styled layers transparent. Is this possible?
Thanks, Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120815/7d3e1134/attachment.html>
