[Qgis-user] Transparency for vector layer
Giovanni Manghi giovanni.manghi at faunalia.pt
Wed Aug 15 06:48:29 PDT 2012
Select the classes and then right click to get a dialog that includes the
transparency option. The overall transparency slider is missing, but there
is a feature request already filed.
On Aug 15, 2012 2:44 PM, "Jonathan Moules" <
jonathanmoules at warwickshire.gov.uk> wrote:
> Hi,
> I know you get set a vector layer's transparency if it is symbolised using
> a "single Symbol", however I can't seem to find any way to make
> "Categorized" or "Graduated" styled layers transparent. Is this possible?
> Thanks, Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120815/c7b1ba14/attachment.html>
