[Qgis-user] Symbology: switch off automatic classification
Nathan Woodrow
madmanwoo at gmail.com
Thu Aug 16 00:49:11 PDT 2012
Hey Tammo,
This is a feature as having to click classify each time when changing
the values was confusing to users so I changed how it works a while
ago.
Currently there is no way to turn it off. You could save out the qgis
qml file and hand edit it to have the new column.
- Nathan
On Thu, Aug 16, 2012 at 5:21 PM, Tammo Jan Dijkema <dijkema at hypercube.nl> wrote:
> I’m using qgis 1.8 to create graduated maps of multiple data columns. For
> this, I use the new symbology implementation, with graduated colors. I would
> like to use one classification for all columns. Usually based on Jenks, and
> tweaked manually.
> In qgis 1.8, when changing the column which is used for the classification,
> the classification is recomputed automatically. This is inconvenient,
> because now I have to enter the ranges for the classification for each map I
> want to make. I expected the classification to only be recomputed when I
> press the button ‘Classify’.
> The workaround I have found is to create my classification, then switch to
> old symbology, which retains the classifcation when I change the column.
> Is this a bug or a feature? And if it’s a feature, how can I switch it offf?
> Thanks for your reply.
> Tammo Jan Dijkema
> Qgis-user mailing list
