[Qgis-user] SVG Fill
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Thu Aug 16 06:50:47 PDT 2012
Hi James,
Yes, that's the general consensus I've had from the off-list replies so
far. However, having now played around with some generously supplied
symbols, I'm not convinced QGIS could symbolise them neatly anyway without
tweaking the SVG itself (i.e. there's no way to specify distance between
symbols for instance).
I'm going to see if I can come up with something anyway and release it back
to the community to augment Lutra's releases (I'm using different columns).
Thanks though,
Jonathan
On 16 August 2012 14:38, James Stott <James.Stott at npaconsult.co.uk> wrote:
>   I believe you need to split the OS svg file into multiple svg files for
> each symbol.****
> I tried this a while ago and gave up in the end.****
> There are examples of QGIS styling for MasterMap on this website but it
> only colours the polygons different colours.****
> http://www.lutraconsulting.co.uk/resources/ostranslator****
> James.****
> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Jonathan Moules
> *Sent:* 16 August 2012 13:44
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] SVG Fill****
> Hi List,****
> I'm trying to symbolise Ordnance Survey MasterMap. The OS are nice enough
> to provide a single SVG file (here:
> https://www.ordnancesurvey.co.uk/xml/resource/OSMasterMapStyles.svg)
> with most/all of their symbology in.****
> My question is simple: How do I use these symbols in QGIS?****
> I've found "SVG fill", which is the one I'm trying to use (i.e., with
> "nonconiferousTreesAndConiferousTreesPattern") and while it does allow me
> to specify the SVG file, that seems to be all I can do. QGIS seems to
> assume that the entire contents of the file should be used for styling,
> while the file has multiple stylings in.****
> I'm guessing mutliple geometries in a single file is valid SVG (it passes
> the WGC validator), so is this something QGIS can handle, or will I need to
> source split files?****
> Thanks,****
> Jonathan****
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.****
>   *James Stott* BSc (Hons) MSc | Senior Professional
> *Nicholas Pearson Associates *| 30 Brock Street | Bath | BA1 2LN
> *T:* 01225 445548 | *M:* -
> *www.npaconsult.co.uk* <http://www.npaconsult.co.uk/>
>   [image: Nicholas Pearson Associates, Logo]<http://www.npaconsult.co.uk/>[image:
> Nicholas Pearson Associates, Latest News]<http://www.npaconsult.co.uk/about-news.asp>
> Information and Registered Address <http://www.npaconsult.co.uk/terms.asp>
> This Electronic Transmission is intended only for the attention of the
> addressee. It may contain privileged and confidential information. If you
> are not the person for whom it is intended, you must not copy, distribute
> or take any action in reliance on it. If you have received this electronic
> transmission in error please notify us immediately by telephone, delete the
> transmission and destroy any hard copies.
> Nicholas Pearson Associates has used all reasonable efforts to ensure that
> this message and any attachments are free from viruses.
> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0)
> 01225 445548, Fax: +44 (0) 01225 312387, Website:
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120816/afed0e20/attachment.html>
