[Qgis-user] SVG Fill
James Stott
James.Stott at npaconsult.co.uk
Thu Aug 16 06:38:45 PDT 2012
I believe you need to split the OS svg file into multiple svg files for
each symbol.
I tried this a while ago and gave up in the end.
There are examples of QGIS styling for MasterMap on this website but it
only colours the polygons different colours.
http://www.lutraconsulting.co.uk/resources/ostranslator
James.
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jonathan Moules
Sent: 16 August 2012 13:44
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] SVG Fill
Hi List,
I'm trying to symbolise Ordnance Survey MasterMap. The OS are nice
enough to provide a single SVG file (here:
https://www.ordnancesurvey.co.uk/xml/resource/OSMasterMapStyles.svg)
with most/all of their symbology in.
My question is simple: How do I use these symbols in QGIS?
I've found "SVG fill", which is the one I'm trying to use (i.e., with
"nonconiferousTreesAndConiferousTreesPattern") and while it does allow
me to specify the SVG file, that seems to be all I can do. QGIS seems to
assume that the entire contents of the file should be used for styling,
while the file has multiple stylings in.
I'm guessing mutliple geometries in a single file is valid SVG (it
passes the WGC validator), so is this something QGIS can handle, or will
I need to source split files?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it,
or disclose it to anyone else. If you have received this transmission in
error please notify the sender immediately. All email traffic sent to or
from us, including without limitation all GCSX traffic, may be subject
to recording and/or monitoring in accordance with relevant legislation.
James Stott BSc (Hons) MSc | Senior Professional
Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
T: 01225 445548 | M: -
http://www.npaconsult.co.uk/
http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
http://www.npaconsult.co.uk/terms.asp
This Electronic Transmission is intended only for the attention of the addressee. It may contain privileged and confidential information. If you are not the person for whom it is intended, you must not copy, distribute or take any action in reliance on it. If you have received this electronic transmission in error please notify us immediately by telephone, delete the transmission and destroy any hard copies.
Nicholas Pearson Associates has used all reasonable efforts to ensure that this message and any attachments are free from viruses.
Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website: http://www.npaconsult.co.uk/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120816/c57b3f04/attachment.html>
Type: image/jpeg
Desc: NPA_Logo.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120816/c57b3f04/attachment.jpg>
Type: image/jpeg
Desc: Email_Footer_News.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120816/c57b3f04/attachment-0001.jpg>
