[Qgis-user] SVG Fill
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Thu Aug 16 07:27:29 PDT 2012
I suggest to stick with the current Shapefile structure outputed from OS
Translator.
Some local authorities use MasterMap in PostGIS format which is similar
to the format of OS Translator. So, any qml files will be useful for
them.
http://wiki.osgeo.org/wiki/Os_tools_for_os
Cheers
Saber
Saber Razmjooei
Lutra Consulting
23 Chestnut Close, Burgess Hill, RH15 8HN
www.lutraconsulting.co.uk
-----Original Message-----
From: James Stott <James.Stott at npaconsult.co.uk>
To: Jonathan Moules <jonathanmoules at warwickshire.gov.uk>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] SVG Fill
Date: Thu, 16 Aug 2012 15:08:45 +0100
That would be great if you could release it if you manage to work
something out.
It must be a lot easier to get the point styles sorted as SVG files or
just a QGIS styles. I may try and create the point symbol ones in QGIS
anyway without using the SVGs for them.
From: Jonathan Moules [mailto:jonathanmoules at warwickshire.gov.uk]
Sent: 16 August 2012 14:51
To: James Stott
Hi James,
Yes, that's the general consensus I've had from the off-list replies so
far. However, having now played around with some generously supplied
symbols, I'm not convinced QGIS could symbolise them neatly anyway
without tweaking the SVG itself (i.e. there's no way to specify distance
between symbols for instance).
I'm going to see if I can come up with something anyway and release it
back to the community to augment Lutra's releases (I'm using different
columns).
Thanks though,
Jonathan
On 16 August 2012 14:38, James Stott <James.Stott at npaconsult.co.uk>
wrote:
I believe you need to split the OS svg file into multiple svg files for
each symbol.
I tried this a while ago and gave up in the end.
There are examples of QGIS styling for MasterMap on this website but it
only colours the polygons different colours.
http://www.lutraconsulting.co.uk/resources/ostranslator
James.
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jonathan Moules
Sent: 16 August 2012 13:44
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] SVG Fill
Hi List,
I'm trying to symbolise Ordnance Survey MasterMap. The OS are nice
enough to provide a single SVG file (here:
https://www.ordnancesurvey.co.uk/xml/resource/OSMasterMapStyles.svg)
with most/all of their symbology in.
My question is simple: How do I use these symbols in QGIS?
I've found "SVG fill", which is the one I'm trying to use (i.e., with
"nonconiferousTreesAndConiferousTreesPattern") and while it does allow
me to specify the SVG file, that seems to be all I can do. QGIS seems to
assume that the entire contents of the file should be used for styling,
while the file has multiple stylings in.
I'm guessing mutliple geometries in a single file is valid SVG (it
passes the WGC validator), so is this something QGIS can handle, or will
I need to source split files?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it,
or disclose it to anyone else. If you have received this transmission in
error please notify the sender immediately. All email traffic sent to or
from us, including without limitation all GCSX traffic, may be subject
to recording and/or monitoring in accordance with relevant legislation.
James Stott BSc (Hons) MSc | Senior Professional
Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
T: 01225 445548 | M: -
www.npaconsult.co.uk
Information and Registered Address
This Electronic Transmission is intended only for the attention of the
addressee. It may contain privileged and confidential information. If
you are not the person for whom it is intended, you must not copy,
distribute or take any action in reliance on it. If you have received
this electronic transmission in error please notify us immediately by
telephone, delete the transmission and destroy any hard copies.
Nicholas Pearson Associates has used all reasonable efforts to ensure
that this message and any attachments are free from viruses.
Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44
(0) 01225 445548, Fax: +44 (0) 01225 312387, Website:
http://www.npaconsult.co.uk
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120816/a62db39d/attachment.html>
