[Qgis-user] SVG Fill
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Thu Aug 16 08:08:02 PDT 2012
Going slightly off-topic now, I'll shortly (within the next couple of
weeks) be releasing my FME loader for MasterMap for free use to all other
PSMA/OSMA members. The default version writes to Oracle (what we use), but
it it can be easily tweated to write to other formats including SQLite etc.
Admittedly FME is neither free nor Free, but we figure quite a few
authorities have it, and if they have someone vaguely capable with FME it
should be easy to use.
Back on topic: My loader provides a OS Style column which is what I'm
getting QGIS to style with. In theory this column is datasource agnostic.
On 16 August 2012 15:27, Saber Razmjooei <
saber.razmjooei at lutraconsulting.co.uk> wrote:
> I suggest to stick with the current Shapefile structure outputed from OS
> Translator.
> Some local authorities use MasterMap in PostGIS format which is similar to
> the format of OS Translator. So, any qml files will be useful for them.
> http://wiki.osgeo.org/wiki/Os_tools_for_os
> Cheers
> Saber
> Saber Razmjooei
> *Lutra Consulting*23 Chestnut Close, Burgess Hill, RH15 8HNwww.lutraconsulting.co.uk
> -----Original Message-----
> *From*: James Stott <James.Stott at npaconsult.co.uk<James%20Stott%20%3cJames.Stott at npaconsult.co.uk%3e>
> *To*: Jonathan Moules <jonathanmoules at warwickshire.gov.uk<Jonathan%20Moules%20%3cjonathanmoules at warwickshire.gov.uk%3e>
> *Cc*: qgis-user at lists.osgeo.org
> *Subject*: Re: [Qgis-user] SVG Fill
>  *Date*: Thu, 16 Aug 2012 15:08:45 +0100
> That would be great if you could release it if you manage to work
> something out.
> It must be a lot easier to get the point styles sorted as SVG files or
> just a QGIS styles. I may try and create the point symbol ones in QGIS
> anyway without using the SVGs for them.
> *From:* Jonathan Moules [mailto:jonathanmoules at warwickshire.gov.uk]
> *Sent:* 16 August 2012 14:51
> *To:* James Stott
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] SVG Fill
> Hi James,
> Yes, that's the general consensus I've had from the off-list replies so
> far. However, having now played around with some generously supplied
> symbols, I'm not convinced QGIS could symbolise them neatly anyway without
> tweaking the SVG itself (i.e. there's no way to specify distance between
> symbols for instance).
> I'm going to see if I can come up with something anyway and release it
> back to the community to augment Lutra's releases (I'm using different
> columns).
> Thanks though,
> Jonathan
> On 16 August 2012 14:38, James Stott <James.Stott at npaconsult.co.uk> wrote:
> I believe you need to split the OS svg file into multiple svg files for
> each symbol.
> I tried this a while ago and gave up in the end.
> There are examples of QGIS styling for MasterMap on this website but it
> only colours the polygons different colours.
> http://www.lutraconsulting.co.uk/resources/ostranslator
> James.
> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Jonathan Moules
> *Sent:* 16 August 2012 13:44
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] SVG Fill
> Hi List,
> I'm trying to symbolise Ordnance Survey MasterMap. The OS are nice enough
> to provide a single SVG file (here:
> https://www.ordnancesurvey.co.uk/xml/resource/OSMasterMapStyles.svg)
> with most/all of their symbology in.
> My question is simple: How do I use these symbols in QGIS?
> I've found "SVG fill", which is the one I'm trying to use (i.e., with
> "nonconiferousTreesAndConiferousTreesPattern") and while it does allow me
> to specify the SVG file, that seems to be all I can do. QGIS seems to
> assume that the entire contents of the file should be used for styling,
> while the file has multiple stylings in.
> I'm guessing mutliple geometries in a single file is valid SVG (it passes
> the WGC validator), so is this something QGIS can handle, or will I need to
> source split files?
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> *James Stott* BSc (Hons) MSc | Senior Professional
> *Nicholas Pearson Associates *| 30 Brock Street | Bath | BA1 2LN
> *T:* 01225 445548 | *M:* -
> *www.npaconsult.co.uk*
> Information and Registered Address <http://www.npaconsult.co.uk/>
> This Electronic Transmission is intended only for the attention of the
> addressee. It may contain privileged and confidential information. If you
> are not the person for whom it is intended, you must not copy, distribute
> or take any action in reliance on it. If you have received this electronic
> transmission in error please notify us immediately by telephone, delete the
> transmission and destroy any hard copies. <http://www.npaconsult.co.uk/>
> Nicholas Pearson Associates has used all reasonable efforts to ensure that
> this message and any attachments are free from viruses.<http://www.npaconsult.co.uk/>
> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0)
> 01225 445548, Fax: +44 (0) 01225 312387, Website:
> <http://www.npaconsult.co.uk/>*http://www.npaconsult.co.uk*
> and/or monitoring in accordance with relevant legislation.<http://www.npaconsult.co.uk/>
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the system manager.
> This message contains confidential information and is intended only for the
> individual named. If you are not the named addressee you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> immediately by e-mail if you have received this e-mail by mistake and
> delete this e-mail from your system. If you are not the intended recipient
> you are notified that disclosing, copying, distributing or taking any
> action in reliance on the contents of this information is strictly
> prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for viruses is taken and it is your responsibility to carry
> out such checks as you feel appropriate.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120816/a9aa7133/attachment.html>
