[Qgis-user] SVG Fill
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Thu Aug 16 08:13:01 PDT 2012
Thats exactly what I want, works great, thanks!
On 16 August 2012 15:25, Andreas Neumann <a.neumann at carto.net> wrote:
> supplied symbols, I'm not convinced QGIS could symbolise them neatly
>> anyway without tweaking the SVG itself (i.e. there's no way to specify
>> distance between symbols for instance).
> The patterns, by definition, don't have spacing between the tiles, because
> patterns should provide seamless tiling. However, you can specify the tile
> size.
> If you want spacing between symbols, you could use the point pattern fill
> editor where you can also use SVG point markers and provide spacing and
> displacement. This requires QGIS 1.8, I believe.
> Andreas
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120816/4e4ab8da/attachment.html>
