[Qgis-user] SVG Fill
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri Aug 17 03:03:53 PDT 2012
Hi Andreas,
I've used this to style up my data, and it was looking excellent good.
However I then moved the SVG files that were being used as the SVG Markers
for the point fill (they were in a temporary directory on my desktop).
Unfortunately this seems to have resulted in all of the point filled
stylings now not working!
Is this desired behaviour?
I expected the SVG styling information to be stored in the QML file, that
way I could just share the QML files and they'd work. This way it basically
renders QML files useless for sharing - everyone will want to put the SVG
files somewhere different because everyone has a different directory
structure.
If I look into the styling as loaded, the SVG maker is pointing at:
"C:/PROGRA~1/Quantum GIS Lisboa/apps/qgis/svg"
If I move the SVG files into there, they still aren't loaded if I reload
the style.
Any thoughts? Hows this supposed to work?
Jonathan
On 16 August 2012 16:13, Jonathan Moules <jonathanmoules at warwickshire.gov.uk
> wrote:
> Thats exactly what I want, works great, thanks!
> On 16 August 2012 15:25, Andreas Neumann <a.neumann at carto.net> wrote:
>> supplied symbols, I'm not convinced QGIS could symbolise them neatly
>>> anyway without tweaking the SVG itself (i.e. there's no way to specify
>>> distance between symbols for instance).
>> The patterns, by definition, don't have spacing between the tiles,
>> because patterns should provide seamless tiling. However, you can specify
>> the tile size.
>> If you want spacing between symbols, you could use the point pattern fill
>> editor where you can also use SVG point markers and provide spacing and
>> displacement. This requires QGIS 1.8, I believe.
>> Andreas
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> ______________________________**_________________
>> Qgis-user mailing list
>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120817/80c266aa/attachment.html>
