[Qgis-user] SVG Fill
Andreas Neumann a.neumann at carto.net
Fri Aug 17 04:22:59 PDT 2012
 Hi Jonathan,
 SVG symbols are always just referenced.
 It is generally good advice to use relative paths in the project
 settings. This influences paths to spatial data files (e.g. shape files,
 tiff files, spatialite), but also the SVG files. Relative means relative
 to the .qgs project file.
 I generally create a directory per GIS project and put the .qgis in the
 root of this directory and svg Files in a subdirectory.
 Alternatively, you can use the central storage of SVG files. This can
 be anywhere in your file system and you can define it in the Global
 Options --> Rendering --> SVG Paths
 Hope this helps.
 Andreas
 On Fri, 17 Aug 2012 11:03:53 +0100, Jonathan Moules wrote:
> Hi Andreas,
> I've used this to style up my data, and it was looking excellent
> good.
> However I then moved the SVG files that were being used as the SVG
> Markers for the point fill (they were in a temporary directory on my
> desktop). Unfortunately this seems to have resulted in all of the
> point filled stylings now not working!
> Is this desired behaviour?
> I expected the SVG styling information to be stored in the QML file,
> that way I could just share the QML files and they'd work. This way
> it
> basically renders QML files useless for sharing - everyone will want
> to put the SVG files somewhere different because everyone has a
> different directory structure.
> If I look into the styling as loaded, the SVG maker is pointing at:
> "C:/PROGRA~1/Quantum GIS Lisboa/apps/qgis/svg"
> If I move the SVG files into there, they still aren't loaded if I
> reload the style.
> Any thoughts? Hows this supposed to work?
> Jonathan
> On 16 August 2012 16:13, Jonathan Moules  wrote:
>> Thats exactly what I want, works great, thanks!
>> On 16 August 2012 15:25, Andreas Neumann wrote:
>>>> supplied symbols, I'm not convinced QGIS could symbolise
>>>> them neatly
>>>> anyway without tweaking the SVG itself (i.e. there's no way to
>>>> specify
>>>> distance between symbols for instance).
>>> The patterns, by definition, don't have spacing between the tiles,
>>> because patterns should provide seamless tiling. However, you can
>>> specify the tile size.
>>> If you want spacing between symbols, you could use the point
>>> pattern fill editor where you can also use SVG point markers and
>>> provide spacing and displacement. This requires QGIS 1.8, I
>>> believe.
>>> Andreas
>>> Andreas Neumann
>>> Böschacherstrasse 10A
>>> 8624 Grüt (Gossau ZH)
>>> Switzerland
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org [1]
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user [2]
>  This transmission is intended for the named addressee(s) only and
> may
> contain sensitive or protectively marked material up to RESTRICTED
> and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
> with relevant legislation.
> Links:
> [1] mailto:Qgis-user at lists.osgeo.org
> [2] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [3] mailto:a.neumann at carto.net
> [4] mailto:jonathanmoules at warwickshire.gov.uk
 Andreas Neumann
 Switzerland
