[Qgis-user] SVG Fill
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri Aug 17 04:57:18 PDT 2012
Hi Andreas,
Unfortunately "relative" doesn't seem to work for QML files (you did say
relative to .qgs files, but I don't actually have a project - I'm trying to
create stand-alone QML files I can distribute both internally and to the
community). My project is set to use relative paths, I then set up my
styling and saved my style to a QML file.
I have this data structure:
/qml/this_style.qml
/symbols/[lots of SVG symbols]
When I then started a new QGIS project, loaded the data then applied the
this_style.qml, it didn't load the SVG symbols.
Looking in the saved QML file, it is saving the *absolute* path:
<prop k="name" v="C:/Documents and
Settings/jmou1.WCC-CORP/Desktop/mastermap_styles/symbols/boulderGeometry.svg"/>
Even if I then search-and-replace this with the relative path:
<prop k="name" v="../symbols/smallnonconiferousTree.svg"/>
It still doesn't load the SVG files.
Even moving the directory structure to: /qml/symbols/ and then changing the
relative term to "./symbols/" doesn't resolve it.
Would this be considered a bug or desired behaviour?
The only way I've found to get it working is to change the QML file to only
point at the file name itself, then make that directory a "SVG path". This
works and seems a fairly decent solution, though personally I'd still feel
better if they were included in the QML file itself, it'd make distribution
easier and importing easier.
Jonathan
On 17 August 2012 12:22, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Jonathan,
> SVG symbols are always just referenced.
> It is generally good advice to use relative paths in the project settings.
> This influences paths to spatial data files (e.g. shape files, tiff files,
> spatialite), but also the SVG files. Relative means relative to the .qgs
> project file.
> I generally create a directory per GIS project and put the .qgis in the
> root of this directory and svg Files in a subdirectory.
> Alternatively, you can use the central storage of SVG files. This can be
> anywhere in your file system and you can define it in the Global Options
> --> Rendering --> SVG Paths
> Hope this helps.
> Andreas
> On Fri, 17 Aug 2012 11:03:53 +0100, Jonathan Moules wrote:
>> Hi Andreas,
>> I've used this to style up my data, and it was looking excellent good.
>> However I then moved the SVG files that were being used as the SVG
>> Markers for the point fill (they were in a temporary directory on my
>> desktop). Unfortunately this seems to have resulted in all of the
>> point filled stylings now not working!
>> Is this desired behaviour?
>> I expected the SVG styling information to be stored in the QML file,
>> that way I could just share the QML files and they'd work. This way it
>> basically renders QML files useless for sharing - everyone will want
>> to put the SVG files somewhere different because everyone has a
>> different directory structure.
>> If I look into the styling as loaded, the SVG maker is pointing at:
>> "C:/PROGRA~1/Quantum GIS Lisboa/apps/qgis/svg"
>> If I move the SVG files into there, they still aren't loaded if I
>> reload the style.
>> Any thoughts? Hows this supposed to work?
>> Jonathan
>> On 16 August 2012 16:13, Jonathan Moules wrote:
>> Thats exactly what I want, works great, thanks!
>>> On 16 August 2012 15:25, Andreas Neumann wrote:
>>> supplied symbols, I'm not convinced QGIS could symbolise
>>>>> them neatly
>>>>> anyway without tweaking the SVG itself (i.e. there's no way to
>>>>> specify
>>>>> distance between symbols for instance).
>>>> The patterns, by definition, don't have spacing between the tiles,
>>>> because patterns should provide seamless tiling. However, you can
>>>> specify the tile size.
>>>> If you want spacing between symbols, you could use the point
>>>> pattern fill editor where you can also use SVG point markers and
>>>> provide spacing and displacement. This requires QGIS 1.8, I
>>>> believe.
>>>> Andreas
>>>> Andreas Neumann
>>>> Böschacherstrasse 10A
>>>> 8624 Grüt (Gossau ZH)
>>>> Switzerland
>>>> ______________________________**_________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org [1]
>>>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>[2]
>> This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use
>> it, or disclose it to anyone else. If you have received this
>> transmission in error please notify the sender immediately. All email
>> traffic sent to or from us, including without limitation all GCSX
>> traffic, may be subject to recording and/or monitoring in accordance
>> with relevant legislation.
>> Links:
>> [1] mailto:Qgis-user at lists.osgeo.**org <Qgis-user at lists.osgeo.org>
>> [2] http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
>> [3] mailto:a.neumann at carto.net
>> [4] mailto:jonathanmoules@**warwickshire.gov.uk<jonathanmoules at warwickshire.gov.uk>
> Andreas Neumann
> Switzerland
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120817/d806dd9e/attachment.html>
