[Qgis-user] Georeferencing fail at picture 2
Giovanni Manghi
giovanni.manghi at faunalia.pt
Fri Aug 17 02:47:35 PDT 2012
On Thu, 2012-08-16 at 18:46 +0000, Lene Fischer wrote:
> Today I gave my first lesson in georeferencing using QGIS.
> 32 university students working with succes. Easy to use and great
> results. It went so fast, that I gave them assignment number two. And
> then it all crashed :-O
this means that qgis crashed (from the following description?
> After setting the first point a point and line was shown - as view of
> an error. And in the GCP table dX, dY and residual pixel all had great
> errors.
> If we tried to activate Start Georeferencing - nothing happend.
> Then by using Settings we could force the program to continue - but
> the result was a stretch map -which was useless.
> As I see it - the program remember the point made in the previous map,
> and calculate with these.
> Has anyone noticed this behavior?
If the issue is the same of the one described here
http://hub.qgis.org/issues/4310
it should have been fixed in qgis 1.8. What version are you using?
cheers
-- Giovanni --
