[Qgis-user] Problem with missing .prj file
Giovanni Manghi giovanni.manghi at faunalia.pt
Fri Aug 17 08:13:26 PDT 2012
The tool "define current projection" works fine, that issue was fixed.
Anyway your point vector overlaps correctly to the other one, but it is
WGS84 and not ALCC.
cheers
-- Giovanni --
On Fri, 2012-08-17 at 09:49 -0500, Proctor, Nathanael wrote:
> I have searched the web and read the user group and found that there might be a problem with ftools when trying to define a projection for a dataset missing a .prj file (http://hub.qgis.org/issues/5257).
> I have attached an example that I need help with.
> The charley_post.zip fileset has the wind speed data for Hurricane Charlie (see http://www.aoml.noaa.gov/hrd/Storm_pages/charley2004/wind.html for source). Notice there is no .prj file and I have searched the NOAA website for any metadata without luck.
> The states_reproject dataset is the US Census tiger file for state boundaries transformed to the North American Lambert Conformal Conic CRS (+proj=lcc +lat_1=20 +lat_2=60 +lat_0=40 +lon_0=-96 +x_0=0 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs).
> I would like to define the wind data to the ALCC CRS, if it works the data should overlay southern Florida.
> Thanks for any help,
> Nathanael
> SOURCE FILES: https://www.dropbox.com/s/8si79e3wxcsj6x6/Problem%20with%20dataset%20missing%20prj.zip
> Nathanael Proctor
> nproctor at tamu.edu
> Qgis-user mailing list
