[Qgis-user] singelband pseudocolor takes a very long time to classify a 21698x24647 raster
G. Allegri
giohappy at gmail.com
Tue Aug 21 00:59:45 PDT 2012
Driver: AIG/Arc/Info Binary Grid
Hi Etienne,
I past the gdalinfo output below.
giovanni
Size is 21698, 24647
Coordinate System is:
PROJCS["unnamed",
GEOGCS["Unknown datum based upon the International 1924 ellipsoid",
DATUM["Not_specified_based_on_International_1924_ellipsoid",
SPHEROID["International 1924",6378388,297,
AUTHORITY["EPSG","7022"]],
AUTHORITY["EPSG","6022"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4022"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",9],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",1500000],
PARAMETER["false_northing",0],
UNIT["METERS",1]]
Origin = (1554747.231034494200000,4924790.769999999600000)
Pixel Size = (10.000000000000000,-10.000000000000000)
Corner Coordinates:
Upper Left ( 1554747.231, 4924790.770) ( 9d41'17.95"E, 44d28'24.73"N)
Lower Left ( 1554747.231, 4678320.770) ( 9d39'49.23"E, 42d15'15.90"N)
Upper Right ( 1771727.231, 4924790.770) ( 12d24'48.42"E, 44d25'28.46"N)
Lower Right ( 1771727.231, 4678320.770) ( 12d17'29.40"E, 42d12'32.70"N)
Center ( 1663237.231, 4801555.770) ( 11d 0'50.41"E, 43d20'54.04"N)
Band 1 Block=256x4 Type=Float32, ColorInterp=Undefined
Min=-5.300 Max=2051.936
NoData Value=-3.4028234663852886e+038
2012/8/20 Etienne Tourigny <etourigny.dev at gmail.com>
> On Mon, Aug 20, 2012 at 11:52 AM, G. Allegri <giohappy at gmail.com> wrote:
> > Hi Etienne,
> >> which ramp(s) are you using, and how many classification steps?
> > any ramp (qgis defaults and cpt-city behave the same)
> >> Can you test in linux?
> > I will do as soon as I restore my Ubuntu VM...
> >> Can you make the file available?
> > Mmm, I suppose no, both for license issues and being a huge file (various
> > GBs).
> > I will try with a subset.
> Hi, I can understand that. Just to have an idea, can you post
> gdalinfo output or at least give some specifics so I can make a
> similar file (i.e. resolution, type, range)
> Etienne
> > giovanni
> >> Etienne
> >> On Mon, Aug 20, 2012 at 7:50 AM, G. Allegri <giohappy at gmail.com> wrote:
> >> > I'm testing the new raster styling with qgis-dev (from osgeo4w) on a
> >> > Windows
> >> > 7 64bit machine.
> >> > My single band raster (21698x24647) takes a very long time to do the
> >> > color
> >> > ramp classification with singleband pseudocolor. So much time that I
> >> > ended
> >> > it before completion (minutes after starting it).
> >> > In QGis 1.8 the (not customizable) Pseudo Color option rendered
> >> > istantaneously.
> >> > The new features in raster simbology are really awesome!
> >> > Thanks a lot,
> >> > giovanni
> >> > _______________________________________________
> >> > Qgis-user mailing list
> >> > Qgis-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120821/73fa5f64/attachment.html>
