[Qgis-user] singelband pseudocolor takes a very long time to classify a 21698x24647 raster
G. Allegri
giohappy at gmail.com
Tue Aug 21 01:05:08 PDT 2012
PS: the projections is EPSG:3003 (or 102091). The OTFR is disabled.
giovanni
2012/8/21 G. Allegri <giohappy at gmail.com>
> Driver: AIG/Arc/Info Binary Grid
> Hi Etienne,
> I past the gdalinfo output below.
> giovanni
> Size is 21698, 24647
> Coordinate System is:
> PROJCS["unnamed",
> GEOGCS["Unknown datum based upon the International 1924 ellipsoid",
> DATUM["Not_specified_based_on_International_1924_ellipsoid",
> SPHEROID["International 1924",6378388,297,
> AUTHORITY["EPSG","7022"]],
> AUTHORITY["EPSG","6022"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4022"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",9],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",1500000],
> PARAMETER["false_northing",0],
> UNIT["METERS",1]]
> Origin = (1554747.231034494200000,4924790.769999999600000)
> Pixel Size = (10.000000000000000,-10.000000000000000)
> Corner Coordinates:
> Upper Left ( 1554747.231, 4924790.770) ( 9d41'17.95"E, 44d28'24.73"N)
> Lower Left ( 1554747.231, 4678320.770) ( 9d39'49.23"E, 42d15'15.90"N)
> Upper Right ( 1771727.231, 4924790.770) ( 12d24'48.42"E, 44d25'28.46"N)
> Lower Right ( 1771727.231, 4678320.770) ( 12d17'29.40"E, 42d12'32.70"N)
> Center ( 1663237.231, 4801555.770) ( 11d 0'50.41"E, 43d20'54.04"N)
> Band 1 Block=256x4 Type=Float32, ColorInterp=Undefined
> Min=-5.300 Max=2051.936
> NoData Value=-3.4028234663852886e+038
> 2012/8/20 Etienne Tourigny <etourigny.dev at gmail.com>
>> On Mon, Aug 20, 2012 at 11:52 AM, G. Allegri <giohappy at gmail.com> wrote:
>> > Hi Etienne,
>> >> which ramp(s) are you using, and how many classification steps?
>> > any ramp (qgis defaults and cpt-city behave the same)
>> >> Can you test in linux?
>> > I will do as soon as I restore my Ubuntu VM...
>> >> Can you make the file available?
>> > Mmm, I suppose no, both for license issues and being a huge file
>> (various
>> > GBs).
>> > I will try with a subset.
>> Hi, I can understand that. Just to have an idea, can you post
>> gdalinfo output or at least give some specifics so I can make a
>> similar file (i.e. resolution, type, range)
>> Etienne
>> > giovanni
>> >> Etienne
>> >> On Mon, Aug 20, 2012 at 7:50 AM, G. Allegri <giohappy at gmail.com>
>> wrote:
>> >> > I'm testing the new raster styling with qgis-dev (from osgeo4w) on a
>> >> > Windows
>> >> > 7 64bit machine.
>> >> > My single band raster (21698x24647) takes a very long time to do the
>> >> > color
>> >> > ramp classification with singleband pseudocolor. So much time that I
>> >> > ended
>> >> > it before completion (minutes after starting it).
>> >> > In QGis 1.8 the (not customizable) Pseudo Color option rendered
>> >> > istantaneously.
>> >> > The new features in raster simbology are really awesome!
>> >> > Thanks a lot,
>> >> > giovanni
>> >> > _______________________________________________
>> >> > Qgis-user mailing list
>> >> > Qgis-user at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120821/9b706f46/attachment.html>
