[Qgis-user] QGIS1.8 on WIndows 7: QtCore
Giovanni Manghi giovanni.manghi at faunalia.pt
Thu Aug 23 01:11:37 PDT 2012
On Thu, 2012-08-23 at 09:57 +0200, "Peter Löwe" wrote:
> Hi,
> installing Q1.8 on a 64bit Windows 7 resulted in a "new entry point / QtCore4.dll error". Is there a documented workaround to solve this ?
> The wroclaw-version sued to run happily on the affected Windows system :-/
look for another copy of the same library in your system, especially in
folders like system32. If you find anyone then rename it and you should
be fine (obviously the evil program that installed the dll in that
folder will stop to work).
cheers
-- Giovanni --
