[Qgis-user] QGIS1.8 on WIndows 7: QtCore
"Peter Löwe"
peter.loewe at gmx.de
Thu Aug 23 01:28:05 PDT 2012
Giovanni,
there were actually five copies lurking in the system. Q works now like a charm. You made my day!
Thanks,
Peter
-------- Original-Nachricht --------
> Datum: Thu, 23 Aug 2012 09:11:37 +0100
> Von: Giovanni Manghi <giovanni.manghi at faunalia.pt>
> An: "\\"Peter" Löwe" <peter.loewe at gmx.de>
> CC: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] QGIS1.8 on WIndows 7: QtCore
> On Thu, 2012-08-23 at 09:57 +0200, "Peter Löwe" wrote:
> > Hi,
> > installing Q1.8 on a 64bit Windows 7 resulted in a "new entry point /
> QtCore4.dll error". Is there a documented workaround to solve this ?
> > The wroclaw-version sued to run happily on the affected Windows system
> look for another copy of the same library in your system, especially in
> folders like system32. If you find anyone then rename it and you should
> be fine (obviously the evil program that installed the dll in that
> folder will stop to work).
> cheers
> -- Giovanni --
Dr. Peter Löwe
