[Qgis-user] DB Manager errors loadin shapefile to PostGIS
G. Allegri
giohappy at gmail.com
Thu Aug 23 04:04:47 PDT 2012
I've just tried to load the corrected version (ERROR2) with shp2pgsql and
it works fine.
giovanni
2012/8/23 G. Allegri <giohappy at gmail.com>
> I'm obtaining the following errors when I try to load (drag&drop) a
> shapefile do PostGIS.
> I'm running PostGIS 1.5 on Postgresql 9.1.
> QGis 1.9 on Windows 7 64bit.
> The first error (ERROR1) I've supposed was an encoding issue and float
> overflow due to the coordinate fields in the DBF.
> The DB encoding is UTF-8.
> The error happens whichever encoding I choose.
> ERROR1
> Error 7
> Feature write errors:
> Creation error for features from #0 to #0. Provider errors was:
> PostGIS error while adding features: ERROR: numeric field overflow
> DETAIL: A field with precision 19, scale 11 must round to an absolute
> value less than 10^8.
> Only 0 of 20 features written
> I've opened the DBF with LibOffice to change encoding and format cells to
> lesser decimals.
> Now I get ERROR2. Considera that I don't have any reg2011 table on the DB
> when this happens.
> ERROR2
> Error 7
> PostGIS error while adding features: ERROR: new row for relation "reg2011"
> violates check constraint "enforce_geotype_geom"
> Only 0 of 20 features written.
> The link to the original test shapefile is [1]
> giovanni
> [1] http://www.istat.it/it/files/2011/04/reg2011.zip
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120823/9358b463/attachment.html>
