[Qgis-user] DB Manager errors loadin shapefile to PostGIS
G. Allegri giohappy at gmail.com
Thu Aug 23 04:03:07 PDT 2012
I'm obtaining the following errors when I try to load (drag&drop) a
shapefile do PostGIS.
I'm running PostGIS 1.5 on Postgresql 9.1.
QGis 1.9 on Windows 7 64bit.
The first error (ERROR1) I've supposed was an encoding issue and float
overflow due to the coordinate fields in the DBF.
The DB encoding is UTF-8.
The error happens whichever encoding I choose.
ERROR1
Error 7
Feature write errors:
Creation error for features from #0 to #0. Provider errors was:
PostGIS error while adding features: ERROR: numeric field overflow
DETAIL: A field with precision 19, scale 11 must round to an absolute value
less than 10^8.
Only 0 of 20 features written
I've opened the DBF with LibOffice to change encoding and format cells to
lesser decimals.
Now I get ERROR2. Considera that I don't have any reg2011 table on the DB
when this happens.
ERROR2
Error 7
PostGIS error while adding features: ERROR: new row for relation "reg2011"
violates check constraint "enforce_geotype_geom"
Only 0 of 20 features written.
The link to the original test shapefile is [1]
giovanni
[1] http://www.istat.it/it/files/2011/04/reg2011.zip
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120823/2a827d83/attachment.html>
