[Qgis-user] loading Web Map Tile Service in QGIS
maning sambale emmanuel.sambale at gmail.com
Thu Aug 23 19:14:29 PDT 2012
Thanks for all the reply. Alister's solution works.
On Fri, Aug 24, 2012 at 8:15 AM, Alister Hood
<Alister.Hood at synergine.com> wrote:
> Specifically, save the xml file from "Option 1)" at:
> http://earthdata.nasa.gov/wiki/main/index.php/GIBS_Supported_Clients#Script-level_access_to_imagery
> Drag-and-drop it into QGIS and it will display fine.
> Of course, see the note at the bottom of the page:
>         "Requirements
>         GDAL version 1.9.1 or greater with cURL support enabled"
>> Date: Thu, 23 Aug 2012 15:33:42 -0300
>> From: Etienne Tourigny <etourigny.dev at gmail.com>
>> To: maning sambale <emmanuel.sambale at gmail.com>
>> Cc: qgis-user <qgis-user at lists.osgeo.org>
>> Subject: Re: [Qgis-user] loading Web Map Tile Service in QGIS
>> Message-ID:
>>       <CA+TxYvOZzDX=zm975i_PcUB0zsEa-rCtu5s6rR-J=BYW+nBrrg at mail.gmail.com>
>> Content-Type: text/plain; charset=ISO-8859-1
>> have you tried gdal tms support? The following VRT file can load
>> openstreemap tms
>> http://www.3liz.com/blog/rldhont/index.php?post/2012/07/17/OpenStreetMap-
>> Tiles-in-QGIS
>> Etienne
>> On Thu, Aug 23, 2012 at 7:47 AM, maning sambale
>> <emmanuel.sambale at gmail.com> wrote:
>> > Hi,
>> > I'm trying to load MODIS Web Map Tile Service [0] in QGIS.  Using the
>> > TWMS version 1.1.1 spec, it can read the capabilities request via the
>> > "Add WMS Layer" dialog.  But I can't get any layer loaded, I get this
>> > error:
>> > Response: <?xml version='1.0' encoding="UTF-8" standalone="no" ?>
>> > <!DOCTYPE ServiceExceptionReport SYSTEM
>> > "http://wms.jpl.nasa.gov/exception_1_1_1.dtd ">
>> > <ServiceExceptionReport version="1.1.1">
>> >   <ServiceException>
>> >     Cannot read data files
>> >   </ServiceException>
>> > </ServiceExceptionReport>
>> > [0]
>> http://earthdata.nasa.gov/wiki/main/index.php/Global_Imagery_Browse_Servic
>> es
>> > [1]
>> http://earthdata.nasa.gov/wiki/main/index.php/GIBS_Access_Methods#Service_
>> Endpoints
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
