[Qgis-user] loading Web Map Tile Service in QGIS
Alister Hood Alister.Hood at synergine.com
Thu Aug 23 17:15:55 PDT 2012
Specifically, save the xml file from "Option 1)" at:
http://earthdata.nasa.gov/wiki/main/index.php/GIBS_Supported_Clients#Script-level_access_to_imagery
Drag-and-drop it into QGIS and it will display fine.
Of course, see the note at the bottom of the page:
	"Requirements
	GDAL version 1.9.1 or greater with cURL support enabled"
> Date: Thu, 23 Aug 2012 15:33:42 -0300
> From: Etienne Tourigny <etourigny.dev at gmail.com>
> To: maning sambale <emmanuel.sambale at gmail.com>
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] loading Web Map Tile Service in QGIS
> Message-ID:
> 	<CA+TxYvOZzDX=zm975i_PcUB0zsEa-rCtu5s6rR-J=BYW+nBrrg at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> have you tried gdal tms support? The following VRT file can load
> openstreemap tms
> http://www.3liz.com/blog/rldhont/index.php?post/2012/07/17/OpenStreetMap-
> Tiles-in-QGIS
> Etienne
> On Thu, Aug 23, 2012 at 7:47 AM, maning sambale
> <emmanuel.sambale at gmail.com> wrote:
> > Hi,
> > I'm trying to load MODIS Web Map Tile Service [0] in QGIS.  Using the
> > TWMS version 1.1.1 spec, it can read the capabilities request via the
> > "Add WMS Layer" dialog.  But I can't get any layer loaded, I get this
> > error:
> > Response: <?xml version='1.0' encoding="UTF-8" standalone="no" ?>
> > <!DOCTYPE ServiceExceptionReport SYSTEM
> > "http://wms.jpl.nasa.gov/exception_1_1_1.dtd ">
> > <ServiceExceptionReport version="1.1.1">
> >   <ServiceException>
> >     Cannot read data files
> >   </ServiceException>
> > </ServiceExceptionReport>
> > [0]
> http://earthdata.nasa.gov/wiki/main/index.php/Global_Imagery_Browse_Servic
> es
> > [1]
> http://earthdata.nasa.gov/wiki/main/index.php/GIBS_Access_Methods#Service_
> Endpoints
