[Qgis-user] QGIS => Inkscape Issues
David Fawcett
david.fawcett at gmail.com
Sun Aug 26 18:08:20 PDT 2012
Andreas,
Thank you. That is good confirmation.
I had tried to ungroup it, but the result was just about 6 more groups. I
later figured out that I had to do another ungroup to get to the individual
features.
Thanks again,
David.
On Sun, Aug 26, 2012 at 4:36 PM, Andreas Neumann <a.neumann at carto.net>wrote:
> Hi David,
> You probably have to ungroup it (potentially several times).
> Unfortunately the file structure of the exported SVG is not optimal.
> Ideally there could be one group per layer with an id indicating which
> group is which layer.
> Hope this helps,
> Andreas
> Am 26.08.2012 21:02, schrieb David Fawcett:
> > I have created a map in QGIS and exported it as SVG. I am attempting to
> > now edit and use the exported features in Inkscape.
> > I am having some issues placing text on the vector paths. It appears
> that
> > Inkscape is treating the whole chunk of SVG exported from QGIS as one
> > object. When I attempt to select an individual street line in Inkscape,
> I
> > get all of the features together. I can use the path edit tool to modify
> > an individual line segment. I can also symbolize it independently.
> > Does anyone have any experience with this? Are there any good tutorials
> > for QGIS => Inkscape?
> > Thanks,
> > David.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120826/2bab1a89/attachment.html>
